Ext HDD failed on receiver, but not on WinVista? | SatelliteGuys.US
sclaws
249
4
Aurora, IL
Turned on my 722 this evening and was greeted with a msg stating my connected USB device was not compatible (a 750GB drive that I've used for archiving for months). Tried a reboot, power cycle of the drive and combinations but no success. The 722 then prompted me to format the drive. Fine. Well...format failed!
OK...thinking failed drive, I popped it onto my Vista machine--boom--works fine. Vista sees 3 'Healthy' partitions. Just to test, I delete the partitions and reformat as NTFS...yeah, its working fine with Windows.
Great. Next step was to reconnect to the 722 in hopes of a successful reformat, but no such luck--same error, same failed format.
Short of trying a new drive does anyone out there have any suggestions?
I had a power supply go bad on me and the EHDs would act up. I plugged a new power supply into my EHDs and now they all work fine.
Thx...hadn't tried either of those suggestions. Will do tonite!
Also, some have had their EHD become inaccessible and after they called tech support and got them to send a "hit" to their DVR, they regained use and access to the drive.
Good luck! Let us know what happens!
Goodfield will be next Dish exec to leave
Over scan
