Expressvu 6100 OTA | SatelliteGuys.US
Expressvu 6100 OTA
I didnt know the 6100 did OTA.
If ExpressVu does to it what DIsh does with their 811 (same box), you should be able to use it as a OTA box. You would need the box hooked to the satellite though as the box does need a signal from the satellite
Didn't a recent update to the 811 kill OTA if the box is deactivated? If so, Bell probably did the same as there updates are based on Dish's.
Bell with 3rd Party Receiver?
Starchoice, the Superbowl, and HD
