Experience with Samsung SD boxes? | SatelliteGuys.US
billbillw
247
Atlanta
Anybody have any experience with the Samsung SIR-S300W or SIR-S70? What differences are there between the two other than the fact that the S300W seems to be the newer model.
I've seen quite a few on Ebay for very low prices. I might be needing to pick up an inexpensive SD box to replace the D10 in my bedroom, which has been acting up lately.
boba said:
If you go to Directvs website you can download the instruction manuals for most receivers.
Yeah, did that, but I'm wondering about good/bad experiences with these recievers and if there is any real difference in the models. The user manual don't really go into specs that much.
I have the SIR-S300W. It's been pretty good I think. Have had it for just over a year (the free unit w/install); the only problems I've had *crossing fingers, knocking on wood* have been - for some reason the caller-id didn't function for a week or two, and after an update a few months ago it would freeze up randomly, which also lasted only a short time.
Oh, I do not know if this is normal (it doesn't bother me much but you it might, take it as you will) if I have the guide up and say it's 759pm, when it changes to 8pm it sort of freezes up for a couple seconds while moving forward. Hope that's somewhat helpful.
At one point I had 3 SIR-S300W's, now down to only two (upgraded to HD on one set)... They have been working great for 2 years, no problems at all.
Price drop for H/D Tivo?
Problem with no VOOM Bill for Direct TV Rebate
