equipment help | SatelliteGuys.US
equipment help
mattweber
2
Corona, CA
Hello,
I am about to sign-up with Dish Network. I am going to need a 3 room setup with a ViP722 in each of those rooms. I would like to have one RG6 line into each of these rooms. What do I need to get to accomplish this?
Here is what I think:
3 ViP722's Receivers
1 D1000.2 Dish
3 DISHPro PLUS Separators
Is this correct?
My last question would be the best way to get this equipment. Should I get the Dish and first ViP722 from Dish Network, then add the additional receivers? Should I buy all the equipment myself?
Thanks,
Matt Weber
Where do you live? A 1000.2 dish will see 119, 110 and 129. If you live outside the 129 footprint the 1000.2 won't work for you. If you live inside the 129 footprint then that's the perfect dish for you since it can feed 3 dual tuners with single cable runs.
Dish Network will lease you 1 or 2 722s depending on who you talk to. The 3rd 722, you'd probably need to purchase it.
Why don't you talk to Claude at Dishstore.net and see what he can do for you. He's one of the site's sponsor and everyone talks highly of him.
Welcome to Satelliteguys.US
Hi Randall.
I live in Corona, CA, so I believe I will be able to see 129. If I can see 129, the equipment I described is all I need to accomplish my goal?
Thanks for the suggestion to talk with Claude, I will give him a call and see what he has to say.
Thanks,
Matt Weber
History HD - Any HD programming ??
