Epix HD on ROKU!! | SatelliteGuys.US
Epix HD on ROKU!!
Juan
33,045
10,293
Moscow Russia
Just use your DishNetwork Website password and a free alternative to NetFlix!! Some decent movies but most were on Netflix.
Works fine on my Roku XD|S. Great to have this addition.
This should make it easier for me to cancel Netflix come September.
Thanks for the info.!!
I will check it out tonight.
I just saw "use your Dish.....":(
1. Create an account at epixhd.com. If you are currently an Epix channel subscriber, then you will be asked to login with your Dish Network (or cable company) user name and password. Otherwise you can try it free for a month.
2. On your Roku go to the channel store and select Epix. When you try to play it for the first time you will be given a code.
3. On your computer go to www.epixhd.com/Roku and enter the code displayed by Roku.
That's it!
PS3 software upgrade to 3D?
Add an Amp?
