EMP 8by1 diseqc switch | SatelliteGuys.US
coathanger
43
I got my new switch today;All is working well on lnb1 thru lnb4, My question is, AM i understanding the instructions correctly? They say to go to the sat asigned to 5, then use the setup like you had a motor in diseqc 1.2, Hold either east or west button until you see max signal.Am i missing something here?
correct. You set up the other ports as motor. Press E or W until you get signal then save as a motor setting. It can be a pain but it does work :)
HD receiver?
Another Multi Switch Question
