Emotiva Audio Bows Improved XPA-2 Stereo Amp | SatelliteGuys.US
gadgtfreek
22,105
865
Lower Alabama
Franklin, Tenn. — Emotiva Audio has introduced the second generation of its XPA-2 stereo power amplifier, a revamped two-channel unit that has new features, functionality and look.
With the new XPA-2 Gen 2, Emotiva has refined the XPA-2's circuit topology. It sports several mechanical improvements like solid machined gold-plated RCA jacks, metal toggle switches for input selection, and "cleaner, bolder aesthetics," with a new high-strength chassis for added durability, the company said.
"Our first-generation XPA-2 was called 'a beast, a monster, an abominable snowman on steroids,' " said Dan Laufman, president of Emotiva. "With the XPA-2 Gen 2, we took that beast and sent her to finishing school. The result is not only more refined performance, but a more refined appearance, as well. And she's flexible enough to stick with you even as your audio system evolves."
The new XPA-2 is priced at $899
Link
Specifications
Number of channels: 2 (stereo mode), 1 (monoblock mode)
Topology: fully discrete, highly optimized dual differential, high current, short signal path Class A/B with premium components throughout
Power output (all channels driven):
1000 watts RMS @ 8 ohm (Mono-Block mode)
500 watts RMS per channel @ 4 ohm (0.12% THD)
300 watts RMS per channel @ 8 ohm (0.07% THD)
Rated power bandwidth: 20 Hz to 20 kHz +/- 0.07dB
Broadband frequency response: : 5Hz to 100kHz, +0 -3dB
Amplifier gain: 29 dB
Signal to Noise Ratio:
1 watt: > 97 dB
Full power: > 121 dB
Input impedance:
unbalanced: 23.5kohms
balanced: 33 kohms
Power supply: 1,200VA toroidal transformer with 45,000uF low ESR storage capacitance
Size:
unboxed: 17" wide x 7 3/4" high x 19" deep
boxed: 23 1/2" wide x 12" high x 24 3/4" deep
Weight: 72.6 lbs (83.5 lbs boxed)
Home Theater Geeks 160: Value Electronics Flat Panel Shootout
Don't You Hate It When ...
