Elavation brackets | SatelliteGuys.US
Elavation brackets
Evelation brackets
Does anyone know where to buy elevation brackets with mount like this bracket.png:coffee
Try doing a search on Ebay, Amazon, internet, etc, for WS9036, think that's the dish model that bracket's from. 36'' Ku dish.
What do you have that needs the brackets? There are probably sources for new stuff but I don't know them.
If it is a large C-band prime focus dish you can find those in the wild...OEM is easiest but you can adapt non-stock polar or H-H mounts to almost any dish if you have the gumption.
For smaller Ku-band offset dishes you can sometimes adapt Dish/DirecTv/Hughesnet/Direcway/WildBlue/Primestar/Channel Master/etc. az/el mounts.
My First Commandment of FTA: Never buy anything if I can make or scrounge it. ;)
Galaxy 19 on DirecTV World Direct?
Dishes ku band
