Edision OS mio 4K - OpenATV 6.2 First-time User Guide | SatelliteGuys.US
Titanium
AI6US
7,690
9,166
Meadow Vista, Northern California
This thread will be used for posting OS mio 4K user guides for North American users and not intended for fielding general hardware or image questions and discussions. Please join or start a separate discussion thread for questions or comments. Thanks!
Enigma2 First Time User Guide North America
Edision OS mio 4K – Factory Load: OpenATV 6.2
Titanium Satellite Dec. 28, 2018
If this is the first time that you are using a STB with the Enigma2 operating system, please take a few minutes to go over back-up and set-up basics. There are many settings and options for the advanced user. Many settings and configurations can be made via WebIF to access the STB via an IP address on a LAN/WLAN, using FTP software and username: root or via telnet. In this post, we will cover the basics using the remote control (RCU).
This guide assumes that you are connecting the OS mio 4K to a fixed C-band satellite dish / C-band LNBF that has been previously aimed and optimized on a known satellite. The steps are intended as a quick overview to familiarize an Enigma Newbie with previous experience setting-up and operating a DVBS satellite system and using the Edision OS mio 4K as a replacement set top box on a working satellite system.
In the future, we will provide additional function and feature guides to help guide beginning users though motorized and multi-satellite configurations, dish aiming and optimization, plug-ins, alternative E2 images, etc.
Critical Notice: The Edision factory preloads the OpenATV version 6.2 E2 image. Please make an image backup before installing or modifying any settings. This will allow you to return or recover to the original operating system image at any future time. Keep this back-up in a safe location as Titanium Satellite will not provide images of your shipped operating system.
An image back-up may be made using FTP, terminal or via the STB to an attached HDD.These steps will cover formatting and mounting a harddrive to the OS mio 4K and creating an image back-up.
STB back-up method onto an External HDD with USB
Initialize and Mount HDD
  1. Connect a NTFS HDD to USB 1 port on rear of OS mio 4K
  2. Press the RCU Menu button
  3. Select Setup then press OK
  4. Select System then press OK
  5. Select Storage Devices then press OK
  6. Select Initialization then press OK
  7. Select HDD then press OK
  8. Press the Red Button to Initialize
  9. Prompt "Do you want to initialize?" will display, Select Yes then press OK
  10. Once the HDD Initialization is complete the display will return to the OpenATV 6.2 screen.
Create Edision OS mio 4K OpenATV 6.2 Back-up
  1. Press the Menu button
  2. Select Setup then press OK
  3. Select Software Manager then press OK
  4. Select Backup Image then press OK
  5. Press the Red button to initiate the backup files on the HDD
  6. When completed, the screen will display "Execution Finished!!". Press Exit three times to return to the Setup Menu screen.
The HDD will now have the necessary files to recover and restore the OS mio 4K back to the shipped factory settings. Store this back-up image in a secure location as you may need it to recover or restore your OS mio 4k to the original factory OS.
Update Software
  1. Select Software Management then press OK
  2. Select Software Update then press OK
  3. In about a minute on an average internet connection, the display will populate with the available updates.
  4. Press the Green button to initiate the update. The update process may take several minutes.
  5. Once the Update is done, Press OK
  6. Prompt "Do you want to reboot?", select Yes and then press OK
  7. The STB will reboot Then display the OpenATV screen.
Delete the factory preinstalled channels:
  1. Press the Nav down or up arrow to display the satellite channel list
  2. Press the Green button to change the Reception lists to (TV) and displaying the two folders for 13.0E Hotbird and 19.2E KU-band Services
  3. Select 13.0E and press the RCU Menu button
  4. Select Remove selected Satellite then press OK
  5. Prompt "Are you sure?"displays. Select Yes and press OK
  6. The screen will now display (TV) and the folder for 19.2E
  7. Press the Menu button
  8. Select Remove Selected Satellite then press OK
  9. Prompt "Are you sure?"displays. Select Yes and press OK
  10. Press the Exit button to return to the main OpenATV screen
All preinstalled channels are now removed from the channel list.
Tuner Configuration for Single satellite and a fixed (non-motorized) C-band dish:
  1. Press the RCU Menu button
  3. Select Service Searching then press OK
  4. Select Tuner Configuration then press OK
  5. Select Tuner B: Availink AVL6762 and press OK
  6. Select Configuration mode and use Nav right or left arrow to change to "Nothing Connected" then press the Green button to save. This disables the unused DVBT/C tuner (as this format is not used in North America).
  7. Select Tuner A: Availink AVL6261 (DVB-S2) and press OK
Configuration mode : Nav right or left arrow to Advanced
Satellite: Nav left or right arrow to select the target satellite (Example: 101.0W C-band)
LNB: Nav right arrow to LNB 1
Priority: Auto
LOF: C-band= 5150 LO Frequency (Select the correct setting that matches the connected LNB's LO and if applicable, the band switch type)
  • Standard KU LNBF = Circular or User Defined= LOF/L: 10750 / LOF/H: 10750 / Threshold 11700
  • Universal KU LNBF = Universal
  • Unicable = Unicable (model associated settings)
Voltage mode: Polarization when using LNBF (Vertical -13Vdc / Horizontal - 18Vdc)
Increased voltage: No
Tone mode: OFF
DiSEqC mode: None
Force Legacy Signal Stats: No
Press the Green button to save.
Press Exit once to return to the Setup Menu screen.
Blind Scanning One Satellite:
  1. Select Blind Scan then press OK
Tuner: Tuner A
Satellite: Target Satellite (example 101.0W C-band)
Search Type: Scan for Channels (or Scan for Transponders if you only want transponders logged and no services logged to the channel list)
Scan Start Frequency: 3400 for wideband or 3700 for highband
Scan Stop Frequency: 4200
Polarization: Vertical and Horizontal
Scan Start Symbolrate: 02 (some images scan lower S/R - more about this setting in later post)
Scan Stop Symbolrate: 45 (some images and modulations scan higher S/R - more about this setting in later posts)
Clear Before Scan: Yes or No (depends on if you want pre-populated transponders to remain)
Only Free Scan: Yes or No (depends if you want only services listed as no encryption or all)
Only Scan Unknown Transponders: No (Yes to only log new transponders)
Disable Sync with Known Transponders: No
Disable Remove Duplicates: No (I suggest that duplicates are edited out after the user confirms)
Filter Out Adjacent Satellites: No (If transponder parameters are used on adjacent satellite, it will not be logged)
Press the Green button to initiate a blind scan of the target satellite.
When the Service Scan is complete, press the Green button to go to the service viewing mode.
Depending on the number of carriers and services, the blind scan for channels could take between 2 and 8 minutes. Average service search and log time is approx 3- 5 minutes on an active typical satellite. Services with no name are assigned a SID with TP frequency / polarity.
Setting Time: Note: The default skin is a 24 hour diplay
  3. Select System then press OK
  4. Select Time Settings then press OK
Timezone: Nav left arrow to select the target GMT offset (Example: GMT -8:00) Pacific Time
Sync Time Using: NTP
NTP Server: pool.ntp.org
Sync NTP every (minutes): 30 (or schedule of your choice)
Press Green button to save
Press the Exit button several times to return to main menu or service viewing screen
Setting Weather Location in the default skin:
  2. Select Plugins then press OK
  3. Select MyMetrixLite then press OK
  4. Select Weather Settings then press OK
  5. Select MetrixWeather ID and enter the ID code found for your location at weather.mynonpublic.com/locationid.html
Unit: Fahrenheit
Refresh Interval (min): Typical is 60
Check is Weather Date Local Date: Yes
Press the Blue button to check the ID validity. If the correct information is retrieved the location ID has been correctly entered.
Enigma2 First Time User Guide North America - Initial Start-up
Titanium Satellite Dec. 30, 2018
If this is the first time that you are using a STB with Enigma2 operating system, take a few minutes to go over this post covering the initial set-up menus for the Edision OS mio 4K running the Factory OpenATV 6.2 image.
Please be sure that you are connecting the STB to your TV using the latest HDMI 2.0 18Gbps type cable. HDMI cables labeled "high speed" should capable of passing the increased bandwidth of 4K signals at lengths up to 9 feet. Older HDMI cables often cause handshake errors between the STB and TV, video and/or audio issues.
If your TV supports 4K UHD (3840x2160) resolution and multi-standards format / frequency, the TV will display all set-up screens. If the TV is not 4K UHD or support multi-standard / frequency) the screen may go blank, display a black or blue color screen or display a warning "Unsupported Resolution or Format" during the set-up. This is normal and the STB set-up will automatically cycle through the available formats until the user observes an image on the TV screen and immediately presses the remote control OK button to accept.
Initial Start-up
  • Connect a HDMI 2.0 cable between the STB and the TV
  • Power ON the TV
  • Connect the DC Power Cord to the STB rear DC jack
During the initial start-up, the STB front panel will display "Boot" then a number count will increase until "49" is displayed. The TV will display the OpenATV 6.2 screen then when "49" is displayed on the STB, display a Set-up screen in German language labeled "Bildschirm Auflosung" on multi-standard models. On non-multistandard TVs, the OpenATV screen may briefly display then disappear.
  • The set-up will now automatically cycle through available settings. Select the clearest video display and immediately press the Remote Control (RCU) OK button. If you did not see any video image display on the TV after 1 minute, press OK button to bypass to the next step.
  • Press the RED button repeatedly to cycle through language selections. Twenty button presses will display English (US) menu language.
Automatic or Manual TV Selection Screen:
This screen is the automatic mode detection or manual TV set-up. I strongly recommend that you select Yes to use the Automatic TV Mode Detection. If your TV or legacy HDMI cable does not support this automatic function, follow the onscreen prompts if No is selected.
Output Resolution Selection Screen:
If you see a list of available video mode selections, use the Nav Down Arrow to select the highest resolution supported by your TV.
If no list is visible, the set-up will begin to cycle through the list of available resolution settings, changing to the next resolution every 10 seconds. When an image is displayed on the TV screen, IMMEDIATELY press the OK button to select that resolution. 2160Pp is the highest resolution and frame-rate (60fps) supported by the OS mio 4K.
Refresh Rate Selection Screen:
If you see a list of available refresh rate selections, use the Nav Down Arrow to select 60Hz.
If no list is visible, the set-up will cycle through the list, changing the refresh rate every 10 seconds. When an image is displayed on the TV screen, IMMEDIATELY press the OK button to select that refresh rate. I recommend that the refresh rate be set to 60Hz.
Language Selection Screen:
English (US)
will be selected. Press OK button to confirm
Start Wizard Screen
Press OK to proceed
After displaying the next Wizard screen, I would highly suggest that you now select Exit the Wizard then press the OK button. You could continue, but exiting now will simplify the installation steps.
Network Wizard:
Press OK to connect configure your network connection
  • Select the WLAN and follow prompts to configure to connect to your wireless network
  • Select LAN and follow prompts to configure to connect to your wired network. I recommend that if at all possible, use LAN for a more reliable and typically faster and more secure network connection.
  • Select Exit Network Wizard if you do not wish to connect to your network or the Internet. I recommend connecting to your network as this will allow updating the image, addons, accurate network time, streaming, etc.
Remove the DC power from the STB rear panel for 5 seconds then reconnect. This will set all of your selections and display the correct language in the menus. Now proceed with the steps to make a back-up recovery image for safe keeping and install the STB into your satellite system.
Congratulations! The initial STB setup is now complete!
General OpenPLi Questions
Let's discuss Enigma 2, etc in this forum
