echo star 7 | SatelliteGuys.US
echo star 7
havenx
211
http://www.lyngsat.com/echo7.html
Lyngsat has these listed as free, how come I can't get them? Pansat 2700a
12253 R
tp 3 LyngSat Logo DISH Network AddressPackages DVB
Nagravision 2 20000-5/6 4100-73
South Florida D Hawkins
070204
WPLG-TV (ABC - Miami) Address Free TV 8830 E
WFOR-TV (CBS - Miami) Address Free TV 8831 E
WTVJ-TV (NBC - Miami) Address Free TV 8832 E
WSVN-TV (FOX - Miami) Address Free TV 8833 E
They are circular polarized so your LNB might not be able to pick them up. Second, they appear to be spot beamed to southern Florida, not sure where you are, but chances are if you are not in south Florida you are out of luck - or so I would think.
Just saw you had your LNB listed in your signature - Looks like the LNB will work, the spot beam may be your issue.
I believe those are on a spotbeam to just the Florida area.
That's what transponder 3 is used for.
So, if you don't live within a couple hundred miles of the target, you won't get -that- signal.
And if Lyngsat wasn't in error, making those signals public should cause them to go encrypted quickly.
In other words, don't bother.
Andrew Channel Master 1.0m/34 inches
Going to play with FTA @ home...
