eastern arc reception | SatelliteGuys.US
jerryd
110
Central Wisconsin
I currently have a 3 lnb dish receiving 110, 119, and 129, Because I am on the edge of the signal for the chicago stations, I HAVE FOUND THAT THE SIGNAL ON 61.5 SAT HAS A STRONG SIGNAL. If I turn my 110,119,129 dish to pick up 61.5 will one of the other lnbs pick up the 72 sat ( I am not concerned receiving the 77 sat as there is not much I would lose by not receiving it. hAS ANYONE TRIED THIS AND DOES IT WORK ?
Thanks !
Just looking at the separation, I'd try aiming the 119 LNB at 61.5, and the 129 LNB sorta kinda at 72.
I don't believe this would work. I have heard of using a 500 dish, (usually used for 110,119). As far as what settings to use on a 500 dish, I'm not sure.
signal at about 45%
My media
