D dgordo SatelliteGuys Pro Original poster Aug 2, 2004 324 1 Chicago Sep 30, 2004 #1 Do they use the same size pole for mounting dishes? Or more specifically can a D* dish be mounted on an E* pole?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,470 15,215 Mankato, MN Sep 30, 2004 #3 yes they both will work
D dgordo SatelliteGuys Pro Original poster Aug 2, 2004 324 1 Chicago Sep 30, 2004 #4 Great, thanks for the help.
Stargazer Supporting Founder Supporting Founder Sep 7, 2003 16,568 340 Western WV Oct 1, 2004 #5 That is the case unless you are to use a SuperDish with Dish Network in which you would need a 2" diameter pole for Type 1 metal dish and 2 3/8" diameter pole for Type 2 fiberglass/plastic dish.
