E*10 TP23 ON HAWAII SPOTBEAM #47 DROPOUTS | SatelliteGuys.US
  • Thread starter Thread starter djmaui
  • Start date Start date
  • Replies Replies 0
  • Views Views 906
djmaui
193
Maui
Is there anyone else in Hawaii having trouble with the HD Locals. In particular, PBS (KHET) is currently just a black screen with no audio and no error message. Some of the other HD locals have done the same thing recently, and some get pixelation and audio drop-outs. They are all on TP 23 e*10 at 110 degrees, which ranges from 60 to 70 on the point dish screen.
If others are having the same problem, then could it be a TP issue?
Could my dish have moved just enough to mess with just one TP on the spotbeam from e*10?
Do I have a bad LNB that is only tweaking the channels from one TP?
Before I start swapping LNB's or re-pointing the dish, I figured it's worth running the problem up the flagpole.
Mahalo for any input.
Finally! A seagate fix on 6.15
New TV doesn't play nice w/ Dish 625
