Dyplexing | SatelliteGuys.US
Dyplexing
wobbie
569
Just a quick question. Has anyone used a dyplexer to combine high speed internet and satellite signal? :rolleyes:
Depends upon your MSO's return path frequency. Most entry level diplexers only utilize frequency down to 40Mhz. Many times the return path is lower. Give the MSO a call and see if they will reveal the frequency to you. If not, it will be trial and error; just make sure the diplexer you select goes down to 5Mhz for best results.
Thanks, for the reply, just another question. How could I tell how low of a frequency the dyplexer will go to?
Welcome Speaker Announced & Other Expo News
Novice question / grounding?
