I am currently not under contract and would be willing to go back on -- as long DISH replaces my dying 722 with a 772K and the OTA tuner (for free). Has anyone successfully done this already?
But will they give me the separate OTA module too?Usually getting a K would be an upgrade and require a new 2 year agreement.
I do not believe is it dish pointing issue, because when the installer tests the signal levels with a handheld meter he gets good values (in the 80s) but that cable is connected to my 722 it reports much lower signal levels (30s-50s). The installer observed this problem at both my my old (where I paid to have the dish re-peaked after getting a new roof) and new home (where they did a DISH Mover install).It does sound like the dish is not aimed to optimum signal strength. Try getting the installer that did the new install out and if he cannot get it better try to get him to switch to the other arc.
If they have to give you the K because they don't have 722s they should give you the module to return your system to normal. If you upgrade to a 722K then you should also be responsible for upgrading to the ATSC Tuner.But will they give me the separate OTA module too?
Once again, contact Dirt for the definitive answers.But will they give me the separate OTA module too?
I am getting the feeling if I just have my 722 replaced with another 722 (meaning I don't specifically ask for a 722K) then it will not be considered an equipment upgrade -- and therefore won't require a new 2 year agreement. Is that correct?
YesI am getting the feeling if I just have my 722 replaced with another 722 (meaning I don't specifically ask for a 722K) then it will not be considered an equipment upgrade -- and therefore won't require a new 2 year agreement. Is that correct?
At both houses? The highest probability is on the receiver, since it's the only common component, unless the switch or separator traveled from old house to new. If the signal level tested good at the point past the switch and separator, then it must be the receiver.THen it could be a wire, connection, switch or separator problem.
Bottom of Forum page. Logged-on members in RED, send PM.Anyone know how you contact DIRT? Or should I just call the installer back and work the replacement hardware through him?
Limited time offer
