dvr thru out the house? | SatelliteGuys.US
paisley_tele
9
pa
here what i got! The installer install a 722k dvr and a 222k. they are both dual tuner just on does the recording (722k). so i have the 722k in the living room then is back fed to the tv2 up stairs, Same way with the 222k hd down stairs and standard tv upstairs.Now tv1 and tv2 on the 722k get dvr service. its there a way i can run a cable to my tv ant input then attach it to the tv line on the diplxer for the tv 2 with a 3 way splitter, would that give me that i can watch the dvr programs in the two other room with with the 222k?
take a look at this thread
http://www.satelliteguys.us/dish-ne...-home-distribution-outputs-together-722s.html
I used this diagram: http://tech.dishnetwork.com/departmental_content/TechPortal/images/pdf/tech/DistributionExample6.pdf
But this is a good diagram too.
http://tech.dishnetwork.com/departmental_content/TechPortal/images/pdf/tech/DistributionExample4.pdf
When you do this make sure that you choose different modulated Channels for both receivers and both Tuners (4 different channels) Then you will use your tv and change the channel to the Receiver/Tuner that you want to watch. The only problem is no HD thru co-ax.
722 favorites
UHF-Remote for 322 Receiver
