DVR question FX channel 248 | SatelliteGuys.US
sferrara
5
Atlanta Georgia
I am a huge fan of Nip/Tuck which is starting season 4 this upcoming Tuesday night.
I set the DVR to tape all seasons for channel 248. However the description of the show does not show HD. I know that this channel is a simulcast. Normally if this is the case you just make sure you set the dvr for the HD channel. I do not see the HD listings for FX. Am I missing something here?
Rumor has it that the first actual HD stuff will happen on Tuesday.
I would set it to record the show and check on Tuesday to see if a seperate HD channel has appeared, and change if nessasary.
Jimbo
chicago il locals
