DVR Advantage 250 | SatelliteGuys.US
DVR Advantage 250
DishDave
898
9
Is the DVR Advantage worth the $10.00 more a month then the 200 ?
Also if i currently have the DVR adv 200 and upgrade to the 250 online. Will the computer know to keep me in the DVR advantage program ?
Also if i upgrade will my commitment change ?
DishDave,
Dish treats the AT250 as a "Premium" channel when you have the DVR Advantage. Therefore, when you add the AT250, you are actually adding one premium to your account (similar to Cinemax, HBO, etc.) As for is it worth it, that will depend on your circumstances. If there are a lot of channels you want, then yes. It would be a personal choice. Personally, if I had a full time job, I would add it right now. Unfortunately, money is tight, so I can't add it right now.
In terms of keeping the DVR Advantage, yes, you will keep it. It will add one more premium to your bill.
No, it will not change the commitment, as you are simply adding another premium channel.
Geoff
How many People at Dish Know?
Had my 722/1000.2/OTA/Dish HD Install Today
