DVR-1100c Package Offer? | SatelliteGuys.US
elder
426
5
Will the DVR-1100c be offered in a "one room package" deal, or must components be ordered separately?
I will assume that they will do the package deal. They use to with the old dvr
normal system with Glorystar is the 36" dish, 2 LNB"s, diseqc switch, 2 short cables (to go from LNB's to diseqc), receiver and install instructions.
All you need is the longer cable to go from the switch to the receiver
I don't recall ever seeing the old DVR on the website either in a system or as a stand-alone. It may because I have only began to look as of late. I check the website often to see if the new DVR is there yet.
I got 75' of cable with my package last year. I didn't have to buy anything extra to install everything. Only thing I needed to do was drill another hole in my house next to my 4 cables coming from my DirecTV dish. :D
Withe the current price of DVRs Dish and Direct TV must see the situation like the fries at McDonalds. They are making money hand over hand with their monthly charges.
Warped Reflector?
Diplexer
