DVI cable recommendation | SatelliteGuys.US
jwprimetime
19
New HD user. Currently using component connection. Is DVI cable worth it? Any recommendations? Are all DVI's created equal?
If your using a fixed pixel display (Plasma, LCD, DLP, LCOS) a DVI connection can provide a small but noticable improvement in PQ.
I second Gary's recommendation. Don't spend more than $20 - $25 on a cable.
NightRyder
jwprimetime said:
I'm using a rear projection Sony 47".
Unless you need to free up a component input for something else, I doubt you'll see enough difference to justify the change. IMHO
NightRyder
Master reset code word for locked channels?
Question about 522 & RecordPlus
