DVD storage solutions | SatelliteGuys.US
Not open for further replies.
freakedout
65
The Boss was watching HGTV and saw someone using CD holders to store dvds without the box. Has anyone tried this. Any input or ideas would be welcome.
The method I use allows you to store your DVD's in a zippered leather case that is available at Best Buy, Circuit City stores and probably online. You can either use the front of the storage case with the picture or most times, there is a loose card in the dvd with the same info. That slips in the clear front of the sleeve and the dvd in the back. You can store 30 of these sleeves with disc to a case. To keep track of the dvd's on my computer, I'm using a great program called "DVD Profiler" that I downloaded. Using that program and the dase system allows me to keep good track of my near 700 DVD's :eek: in my library. Good Luck with it!
Terk Unveils Sirius Home Antenna
NESN and YES Network to Merge?
