dvd playback xbox 360 | SatelliteGuys.US
Compared to? What details are you looking for?
vs
Other game systems:
Wal-Mart cheap stand-alone DVD player:
Decent mid/entry DVD stand-alone player:
High-end stand-alone DVD player:
Xbox 360 progessive scan dvd
vs a decent progessive scan dvd player
i don't think you will notice much differance if any. just make sure you use the component cables and you have the switch on the cable switched to hd. (if that is the setup you are using)
i use it to watch DVD's...i use component video on my HD 46" Sony @ 720P upconverted...picture looks pretty good....better than SD I would say
What is the Xbox outputting? If you have it set to 1080i, is there any chance it may be upconverting a 480i DVD to 1080i?
I doubt it becuase so far most upconverting DVD players use a DVI output.
Still looking for XBox 360s? Try this....
COD2 - XBox Live
