DVB PCI card with HD | SatelliteGuys.US
techno935
1,048
Pompano Beach, FL
Most of them do handle the 4:2:2 broadcasts. Are there any that don't? I've broken down and decided to get one so I can see the Gator basketball games. Any thoughts on what NOT to get. Thanks in advance.
I would suggest getting a card that is compatible with the Software that you plan on using because most will do it as long as you have the correct Video codecs installed.
It's not up the card.. it's up to the software. As said before.. get a card that works with the software you will use to watch the signals with. I would make sure the card works with TSReader and DVBDream. Two awesome but different applications for DVB devices.
Yes. Don't get a Nexus-S
It won't do hi def in hardware, so it's a waste of money.
Also, if you see a Kworld K-100 (?) card, run do not walk as far away as possible.
It's a dog!
(arf! arf!)
Good advice.
I would add MyTheatre to the software list, to make three.
Okay kiddies get out your marshmallows because I sense a flame will be roaring any moment now.... ;)
Don't have either. Don't have a PCI card either (I suck), but eventually. I've heard good things about DVBDream too, but if you need Closed Captioning support I believe that MyTheatre is currently the only one that offers that.
When I first got into DVB-S PCI cards , Dream seemed easier to set up & get working .
But I ended up using MT . For a couple of years , now .
I suggest a machine close to the 3 ghz range for HD . And not a Celeron . Especially if you run ( as I do ) cheap out of the box EMachine type of computer w/ onboard audio & video .
It takes a lot more CPU yo process HD .
Wyr
not gonna argue
I've had my troubles with MT.
However, I'm still looking for something else to handle the Twinhan Starbox properly.
DVBdream won't.
RitzDVB doesn't seem to.
TSreader was $100 last time I looked.
DVBdream won't.
My friend says Starbox works with ProgDVB and MyTheatre. That would be for Starbox I. Starbox II has BDA drivers, so it may work with other programs.
Should I Install D*tv Dish for more FTA?
DVB-S solution for low-profile PC
