If you enjoy what a Diseqc 1.2 H_H motor does for FTA DVB check out Eagle Aspen Rotr 100. Diseqc 1.2 for your OTA.
Sound interesting, do you have a link ?
Here is the install guide
http://www.eagleaspen.com/admin/download/fujian/file_55.pdf
Unlike a satellite receiver driving an HH motor, ATSC tuners aren't designed to move an antenna so it doesn't look like you can tune to channel 5 and the anntena will move. still a cool device
1Adam12, your post with the antenna picture reminded me of lafayette, haven't thought of them in years! BUT>Their website totally locked up Firefox (64bix in linux) , so anybody else trying it, I warned ya. google shows some video from a guy who says lafayette is going out of business, for all I know they may already be gone. I got their web catalog page to load but it comes up empty. If the Gray-Hoverman antenna doesn't work for me, when I build it, guess I'll find another place that sells those parabolic jobs!
Looks good as long as you don't somehow lose signal running thru it. It would definitely be helpful here
I have an Eagle Aspen from solid signal. to get around the signal loss i just ran two rg6 runs. one goes from the tv or rcvr direct to the antenna (or winegard amp in my case) and the other run goes from the controller to the motor and use it standalone.
How well does the 9521 retain accuracy for you? Mine requires synchronization from time to time to restore aim accuracy. I really like the idea of the hall sensor in the Rotr 100 & will likely buy one if my 9521 fails.I've had one of these for years.
http://www.crutchfield.com/S-KrSbnUikkdg/p_6599521A/Channel-Master-9521A.html
Program in where the channel is and then you're good to go. Or you can point it in any direction you want.
Limited time offer
