lacubs SatelliteGuys Pro Original poster Oct 9, 2007 1,596 42 Erie, Pa May 9, 2013 #1 every once in awhile, the guide doesn't come in, like daily, does your guide end at 5/20?
whitewolf8214 SatelliteGuys Master Pub Member / Supporter Lifetime Supporter May 13, 2004 40,379 799 Space May 9, 2013 #2 MY Guide ends at Monday May 20th at 6pm and did a reboot and hope it helps and will find out later or tomorrow
lacubs SatelliteGuys Pro Original poster Oct 9, 2007 1,596 42 Erie, Pa May 9, 2013 #3 thanks , the guide finally came in, sometime i get a little worry about the little things
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,108 8,471 NW Ohio - Buckeye Country May 9, 2013 #4 Your guide on the newer DVR recvrs go for 14 days .... I typically can go out 12 or so, usually not 14. Your first 2-3 days should fill in almost immediately, the rest usually takes a few days.
