I thinking about adding some dual LNB's to my system to run 2 receivers. I know the receiver sends power to the LNB... would the power be going to the LNB from both receivers? Does the LNB block the power from one receiver?
Be careful of the dueling LNBs....keep your distance
Both receivers would power the dual LNB as designed. One box could be off and the other would work just fine.
LOL dueling LNB's
Are both receivers sending power to the dual LNB at the same?
Thanks guys... I was curious as to how that worked?
Limited time offer
