OTHER - Dual C-band Feedhorn | SatelliteGuys.US
OTHER Dual C-band Feedhorn
johan
SatelliteGuys Guru
147
32
holland
Hallo Members ,
is it possible to use a dual c-band feedhorn to recief the c-band signals to fine-tune the lnb to the Dish.
at 1 lnb the tv ,and the other lnb a measuring instrument . or does that not work !?!
Mvg
A basic answer is c-band satelites send horizontal signals and vertical waves. So with a dual feedhorn you put another c-band lnb on like the one you already have. one lnb receives reception of vertical waves and the other lnb receives horizontal waves. So magic static gave you good advice. No one can give you much help till you research on your own on how satelites works.
[Viewsat] Viewsaat VS2000 Ultra Lastest Firmware + Help
OTHER Recommend a new FTA reciever
