DTV Slimline HD Dish searching for signal | SatelliteGuys.US
rjwest
3
This last week I have really had a problem with searching for signal. I had DTV installed about 9 months ago. I have 1 HD receiver and 2 regular receivers. About a week ago I started having problems with getting the upper channels. Channels 3 through 79 to include HD still came in great this happened on all receivers, so I don't believe they are the problem. It has been hot 95-100 for the last couple of weeks.
In the evening about 9:00 P.M. the upper channels come back on, on all the channels picture is great. When I come home from work and try the upper channels I get searching for signal sometimes multi-switch problem. Does anyone have any ideas if the heat is affecting my dish?
rjwest
the MS in the LNB may be getting too hot. I suggest unpluggign all your receivers for about 5 minutes to let the switch cool off for a bit...then plug them all back in...
AU9S 5LNB Azimuth, etc.
NYC locals in Florida?
