DTV satelite | SatelliteGuys.US
DTV satelite
nigelcaruthers
39
2
charlestom
Went to Satellite finder and I don't know which DTV satellite to use to get coordinates to receive DTV signal for Slimline HDTV now i've re-located to Greensboro, N.C.
Help please.
Cheers
nigel
Help please.
Cheers
nigel
Try this :
Satellite: 101W DIRECTV 4S | DIRECTV 9S | SES 1
Elevation: 42.5°
Azimuth (true): 213.4°
Azimuth (magn.): 221.8°
From Dishpointer dot com
Look for the 101 Sat
there are two "favors" of that dish and depending which one you are pointing determines the window needed to get the sats.
No clue what your talking about ...
Fwiw, I've set up plenty Slimlines all the way down to the single lnb set up back in the day.
He should be pointing at the 101 Sat.
He can always go into the dish pointing screen and put in his zip and it will give him the skew, az and el for his location. He just has to select the right dish type in the pointing screen.
Reactions: Jimbo
DIRECTV Launches Kids App
Onkyo receiver clicking noises and input change
