DTV remote & Denon receiver | SatelliteGuys.US
Yes, but the volume keys never work initially with ANY audio code, reason is the volume keys won't work at all without a tv code programmed to the tv device, once there is a tv code its volume is now in the way but that can be remedied.
So with tv code in, and denon code that partially works your receiver programmed to either AV1 or AV2 device, to get the volume in single device:
1. av1 or av2
2. press and hold MUTE & SELECT, wait for two blinks, release
3. enter 9 9 3
4. press VOL DOWN
If you want the Denon volume in ALL device do the following instead:
1. av1 or av2
3. enter 9 9 3
4. press SELECT
1. av1 or av2
3. enter 9 9 3
4. press VOL DOWN
1. av1 or av2
3. enter 9 9 3
4. press SELECT
Edmund, you are a genius! Thanks for this information. It worked great with my Yamaha amp, too.
Questions from another one looking to abandon the E* ship
H24-700 Installation Questions
