Dst 1000 | SatelliteGuys.US
Dst 1000
vette86pc
5
Does anyone have a DST 1000 card? I was wondering if it will work with MyTheatre, ProgDVB, or Ritz. I would also like to know if there are any problems with them. Thanks in advance.
Hey Vette,
I have had one 2 years or so, and I have had no problems,
Its basically a twinhan, I belive I read there are getting few and
far between to find. I bought myself a extra one and put it up, in case mine goes
down, and it will work with MT and prog. for sure, just during setup, reconize it as a twinhan compatiability, and it should work just fine.
I saw these on a web site, emailed the owner about them, he said they are the same as a 1020a. He said Twinhan licensed Chaintec to make them. They are indeed getting scarce, he had them for $39.99 each, and said he wasn't getting any more after his stock sold.
Same as a twinhan 1020a except they removed the thermal fuse and installed a choke. Seems to be an improvement, works diseqc switches well. It turns the LNB power off by a relay, just like the 1020a. Comes with their own software which looks like a copy of Twinhan's. Uses same windows drivers as far as I can tell. Mytheatre see it as a twinhan.
A real bargain at $39.00
Hindi Channels on Telstar 5???
fortec star lifetime ultra
