DSR905 Question | SatelliteGuys.US
DSR905 Question
kb2kir
182
Norwich, NY
Hey folks,
Easy one....
I have a B1satstack LNB on my 10 footer.
I have been told the DSR905 will not play well with it.
Do I have the option to slave it off myCS6000?
If so, how would the connections be made ?
wont work. I have one and all I can get is vertical on the 905. I tried using the loop out of the CS5000 and nothing
the problem is the H polarity is at 5750 LNB LO so the 905 cant figure that out. If you drop the LNB back to 5150 then all H polarity is off by 600mhz (4000 becomes 3400)
Thanks, Ice.
I have a 7.5 foot Echostar mesh. I'll put it up in the spring and use a "normal"
Chaparral feed.
What have I got here?
what kind of receiver do i need
