DSR505 Remote Help | SatelliteGuys.US
DSR505 Remote Help
cspiteri
385
4
Can someone walk me thru the procedure to program my DSR505 remote to control the volume on my Mitsubishi television set? I have the codes as listed in manual for my DSR922. Also, is there a procedure for "scanning" the remote tables if the three digit codes I have don`t work??
IIRC press and hold down the button you want to control (TV as example) until it stays steady
Then enter the code...light will blink 3 times. Try TV...if it doesnt work repeat
Ice - Your procedure didn`t work. I used the codes from my DSR922 manual. I don`t know if the 922 manual doesn`t list the correct code or if there`s a cockpit error in my entering them.
Is there a procedure for scanning any remote tables within the remote???
Mitsu codes
Mitsubishi 1004, 1005, 1023, 1034, 1070, 1071
...................................... 1072, 1122, 1123, 1129
............................ 1149, 1172, 1173, 1192, 1194
Ice - Once again. THANKS for your competent help!!!! The codes in my DSR922 manual were 3 digit. That`s why it wouldn`t work.
cool. I thought they were the same in both...guess not ;)
Glad you got it working...which reminds me. I gotta change the code in mine one of these days for the new TV I got ;)
lol, i was thinking the same thing.
Ice, can we have a thread dedicated for pdfs of manuals that is stickied? This would be very useful.
I'll post the manuals that are in pdf....some links on the shaw site only open a new window (like how to program the remote)
Need Shaw Direct Receiver Help Please
Starchoice (Shaw Direct) manuals
