DSR505 Ebno #'s on HD channels low?? | SatelliteGuys.US
Mr Tony
3,425
15,017
Mankato, MN
Well after having my quad LNB blow up and being F1 only for a few months I finally got a dish at 111.1 for the HD channels
Got NFL Net tuned into +9.2, the French freebie channels at +9.0 ebno and EWTN at +8.8
so the dish is aimed right....but when I tune to a HD channel like TSN the ebno is like +5.8 which seems really low. I guess when your F1 channels are at +10.7 and +10.3 anything lower you question
I even checked the HD channels on F1 (SN East, Golf, CTV) and those read low too (around +5.8 to +6.0)
I take it this is normal for the HD channels to have the ebno be that low??
Iceberg,
Assuming the Ecb/No on my 530 is the same as Ebno on your 505 ...
Set on TSN HD 280:
Tuner 1: Ecb/No 8.1 dB
Tuner 2: Ecb/No 8.5 dB
Set on (something French) 700:
Tuner 1: Ecb/No 11.6 dB
These numbers obtained in Seattle.
HTH
Brad
I goofed and the F1 HD channels are around +7.0
I'll try and move the dish a little bit. possible obstruction (from another dish) ;)
problem solved....partial obstruction
F1 HD channels are at or near +8
F2 channels read between +6.8 and +8
Thats what happens when you have dishes on the roof and on the deck...the dish on the roof was partially blocking the dish on the deck
Moved the dish on the deck back to 107.3 and moved the motorized one to 111.1 and now its all working :)
upgraded the setup and now we have numbers I like :)
moved the 1.2m dish to 111.1 and now I get some better numbers
SD (ebno #'s)
420 NFLN 13.5
559 EWTN 11.5
700 SRC 13.9
711 TVA 13.8
750 RDS 13.3
HD
244 SRC 9.8
261 SNETO 9.3
280 TSN 9.1
274 SPEED 9.8
286 CBSE 9.9
291 FOXW 10.1
295 ABCW 8.8
me much happier now :)
Added a 2nd LNB for 107.3 and ghetto rigged it (thats what I do best) and got really good numbers
200 10.3
299 8.9
302 10.3
351 11.0
362 10.0
395 9.9
400 10.7
418 11.8
500 9.0
522 10.7
540 10.6
HD on AnikF1 is at 7.8
and some pics :)
F2 Satellite Reception Problem
List of events on PVR530 empty
