dsr 922 lost digicipher east | SatelliteGuys.US
vassho
71
maybe some one can help
I all of a sudden lost my subscription channels and all digichiper channels the light wont even come on
but its only from G3 east
I am getting all the GO , W5 GO and west are ok but no digicipher east of GO not even a light on the dsr 922 it started like loseing signal then lost them
Its Strange
have you tried moving the dish either way and watching for the light? Sounds like it just needs re-tuned.
Its not a adjustment issue as i thought it was
I am getting all my analog stations just not digicipher east of GO and also just noticed i also noticed my trip counter is at 0
I am getting the channles on GO and lost some of them on W% but not many and lost everything but analog east of GO
Thanks for the reply as I do appreciate it
I am going to post a new topic as i just come to find out
its not picking up the Horz feeds as only vert I am using a C Band LNBF
Update fix
I went into set up and it would not let me check c lnbf and every time i tried to high light it it would pass it up would not want to stop.
so i checked c/ku lnbf and it worked.
then i went back in and it let me high light and check c lnbf
Not sure why it did this but for some reason the receiver went screwy had its own mind
but as i tricked it into the c/ku lnbf to get this working
it then let me check the c band lnbf so far it has stayed there
dsr 922 lnbf Horz problems
seeking AJAK Mount ?
