Drake 1424 Vs UNIDEN UST4500 | SatelliteGuys.US
kelleyga
320
I have a mesh 10 foot dish. I am intereste in getting FTA, channel Teletica on PAS 3r. That is my main mission. After acomplishing that anything else more is good.
I need to buy a receiver that can move my dish using my linear mover.
1) Which of these receiver is best?
2) I mean, which will give me what I need and extra for my dollar?
3) They are used units but in good shape. How much should I pay at the most?
You will need a fta rec. to go along with one of these units, both rec. You mention will do what You want as far as moving Your dish and changing You polarity. $40.00 is just about top
dollar on used units. You will need to slave the units or use a switch that will give you analog as well as fta, hope You don't have trees in the east. to keep You from getting Pas 3
No DVB receiver that I'm aware of will directly control a BUD (Big Useful Dish, your 10' mesh). These receivers use DiSEqC and USALS to control small motors that move 30" - 1 meter dishes.
You can buy something called a V-box that converts the small motor DiSEqC commands to drive a BUD actuator.
Also, you might want to look at the Pansat 2700 or 3500 receivers, they have terminals that will control the polarity (horizontal or vertical) on your BUD.
Distance from objects when installing dish?
Mpeg 1.5
