DPP44 and 7200? | SatelliteGuys.US
DPP44 and 7200?
DishSatUser
302
Seattle, WA
Can anyone confirm that the 7200 would work with the DPP44? :confused: Please don't bother to inform me about the "Superdish" incompatibility, I'm aware of that. :no
Just wanted to confirm that the "legacy" support of the DPP44 would work correctly for 110/119 for a 7200.
I'm looking at more receivers over the long haul and feel that it would be better to get a DPP44 first instead of just a DishPro adapter.
Thanks! :)
Sure would be nice if Dish decided to add the FSS satellite software support to the 7200, that would be very nice indeed. How difficult would this be over the Sirius support that they've already added?
It will work, but the 7200 will only see 3 satellites on the first 3 ports of the switch. If one of the satellites on the first 3 are 105 or 121 it will only see 2 satellites. The DPP44 manual recommends that the SD satellites (105/121) be connected to the 4th port so that receivers like the 7200 will not be bothered with them.
Maybe a problem with 269 upgrade
811 Format Problem
