DPP Twin LNBF vs. DP Quad LNBF-what's better? | SatelliteGuys.US
chinohillsboy
I have a Dish 500 with a two line LNBF feeding a 508 and 301. I'm thinking of upgrading the 301 to a dual tuner 522 or 625. What would be better: using a Dish Pro Plus Twin LBNF (which I think will not require me to run an additional line) or to use a Dish Pro Quad LNBF and cap off the one unused feed? I don't know if I correctly explained this issue, but I would like the best quality and don't mind doing a little extra work, if it makes a difference. Thanks.
Niether LNB will give you better picture quality if that is what you are asking. I've done lots of experimenting. Picture quality and signal strength is identical.
Check your bill carefully
Phone connection
