DP34 No Signal Strength | SatelliteGuys.US
SBD
57
I can't figure out what is wrong with my system. I have a Dish 500 and a Dish 300 both connected to a DP34 Switch. I have a 510 connected to the #1 to the receiver. No other receivers are connected at this point. The receiver shows 0 signal strength. When I have gotten it to work, it would only work with one receiver connected at a time. Now not even the one receiver is working. Is the switch going bad??
SBD
SBD
Have you tried the other 3 ports? Also you might try a switch check with no coax connected to the reciever to clear the matrix.
Then by-pass the 34 and go straight to reciever and run signal strength check.
PocketDISH: Why must customers deal with Archos?
622 OTA tuner gone nutty
