DP311 to HDTV | SatelliteGuys.US
DP311 to HDTV
I'm thinking you'll have to do a channel scan, correct?
If your 311 is connected to a conventional TV antenna, you would need to run a scan with the 311 turned OFF to find local stations. If you don't have an antenna connected, don't bother scanning.
Should I just run A/V?
Yes, as vegassatellite points out, A/V will probably give you a better picture and sound. In this case, if you have an Over-The-Air antenna, you would need to connect that directly to the TV's antenna input.
So you know, if the picture looks bad, that's what happens with SD content on an HD TV.
When you edit your original post to say "problem solved", that defeats the purpose of a forum like this, so somebody else who has a similar issue can find a solution.
Getting a new deal under wife.
Did a leprechaun stop my recording?
