DP301 Forgot Password. Help! | SatelliteGuys.US
carnavore
3
Is there any way I would be able to retrieve my lock code without erasing my settings? Any help would be appreciated.
Thanks,
Dave
If your birthday on your profile is correct, your parents probably set the password to prevent you from doing what you are planning on doing!
It's issues like this that make it the policy to have to call DISH themselves. If I was a parent who had a child under 18 I wouldn't want them finding an unlock code to unlock adult programming.
:D StevenD, that was pretty resourceful. :D
carnavore (or is it carnal-vore), shame on you... :dev
but nice of you to keep your tone lighthearted after being pre-emptively busted :)
stick around on here though, lots to learn while waiting to turn 18 :)
fyi, I believe the only way to get around the code is to call Dish, Dish has no way to look into the reciever and find out what the code in the box is, so therefore they would have to reset the box, killing ALL preset setting. So in other words, you're parents will find out.
Well, of course there is a way, you can dump the boxes NVRAM (using the remote actually), and get the code, but .... your too young for that one :)
942, Network HD, NFL HD....I don't want much
Setup of 811
