DP vs DPP equiopment | SatelliteGuys.US
ccash
238
Long Island
Help me out with something –
I have a 2-dish configuration - 110/119 and 61.5 (both Dish 500)
I have Dish Pro LNB's and 2 DP-44s
I have one 622 taking 2 feeds and one 503 and one 508 taking one feed each.
I am adding one 722. It would be a real pain to snake a second feed to the place I want to add the 722. I would like to use the 1 feed solution and the separators on the 622 and 722.
If I change the switch to DPP-44, do I need to change the LNB's to DPP's or are the DP LNB's compatible with the DPP switch.
Your information is a little confusing. I'm guessing the DP-44 you mention is really a DP34, but I don't understand why you have two right now.
But to answer your last question, yes, DP LNB's work with a DPP-44.
Tailgaiting questions
7100/7200 software no longer available from WebTV/MSN?
