DP-quad-1????? | SatelliteGuys.US
DP-quad-1?????
Spinerep
42
Waterloo,SC
I looked up my switch information and the system info shows my switch as being a DP-quad-1, the funny thing is when I looked it up before it said that the switch was a DPP quad, why would it list it differently? Which switch is this? I really haven't seen this switch mentioned, I even went under the house to find the switch, and can't seem to find it. Installer is coming out on April 1st to install Dish 1000 and Vip 622.
Russ
DP Quad 1 means your reciever is hooked up to the first output on the 119 side of a Dish Pro Quad LNB. The "switch" is in the LNB on your dish. There is NO DPP Quad. If there was, these folks would not be griping about DPP 44s, because most of them don't really need a DPP44.
Ebay Dishnetwork ?
My 2 cents !!! You'll love it!!!!
