DP 21 | SatelliteGuys.US
DP 21
whatchel1
9,098
51
Great High Plains
Does a DP 21 work with a separator on a 722k? I'm going to put my larger dishes up again and ran onto a DP 21 switch found from a removed install. Since I really only need 61.5 & 72.7 now was thinking about not using the DPP44 and only 2 dishes.
DP21 is basically the same as a SW21 except it is for Dish Pro technology. It combines 2 satellites onto one cable you would need 2 of them and 2 cables for a 722.
tru volum update
found 119 129 but not 110
