downloading my channels | SatelliteGuys.US
gabshere
3,720
21
Rison , Arkansas
ok i think i have everything
and it all connected
now i don't have a lot in the receiver
as per channels but i thought i would
check out editing it . i have CM 1.14.3
i think thats whats being used to edit
now with my coolsat dow do i get the data to the pc
i've went to the data area but the don't sync
of course coolsat isn't listed so what do i look for is there another
type of receiver that i can choose to link up with.
thanks
i think it is but , and this is where i slipped up lol
i went and did a search here and found iceberg had posted the loader
now i just got to figure out how to download it.
cm will support it after i download but. you know
ive never used CM either. so i will look at the ones
iceberg posted and try to figure out which
is easy to use.
i actually have the channels edited (manually
deleted all except the radio)
and i do have a couple of question
about sat names can they be edited / changed
and i will probably have to find a inexpensive ac-3
decoder , my old surround system doesn't support
it.
What's up with the format in these posts? Using your phone or something to compose them?
Just wondering, I've seen plenty of your posts before and don't remember any that look like these. :)
different screen resolution now its better :) just looked like i was typing into a small box . now it looks better :)
didn't have time to finish this project , 4 am comes early
Signal quality different on two receivers
Chaparral Monterey as Analog, questions...
