B bnewt SatelliteGuys Pro Original poster Oct 6, 2003 1,488 550 Shepherdsville, Ky Oct 3, 2014 #1 I don't recall seeing one on any picture. How does the IR remote work if it doesn't?
D dishrich SatelliteGuys Pro Sep 8, 2003 3,419 567 Springfield, IL Oct 3, 2014 #3 Unfortunately, you cannot change IR codes from default (1) like you can on other E* receivers...
B bnewt SatelliteGuys Pro Original poster Oct 6, 2003 1,488 550 Shepherdsville, Ky Oct 3, 2014 #4 thanks guys
D DishSubLA SatelliteGuys Master Apr 9, 2006 5,450 1,418 Oct 5, 2014 #5 Using IR for Slingbox and Zigbee otherwise. Interesting that no way to change IR access code. Hope I am not in situation where I need to.
B bnewt SatelliteGuys Pro Original poster Oct 6, 2003 1,488 550 Shepherdsville, Ky Oct 7, 2014 #6 hopefully, I won't have to use the IR setup........I think I will just purchase another remote for use in the other room
R riderj SatelliteGuys Family Pub Member / Supporter Aug 21, 2007 118 101 Branson Oct 22, 2014 #7 By IR remote do you mean one of the grey ones say from the 622? Can you have a combination of the new Hopper remote and one of the old ones?
lucky86 SatelliteGuys Pro Pub Member / Supporter Sep 19, 2012 3,941 179 By the sea, in a land called Honalee Oct 22, 2014 #8 Yes, you just enable ir on the Hopper via the remote manager. Also make sure your 622 remote is in ir mode and not uhf. Posted Via The FREE SatelliteGuys Reader App!
R riderj SatelliteGuys Family Pub Member / Supporter Aug 21, 2007 118 101 Branson Oct 22, 2014 #9 Thanks. You just made me a happy guy.
