Does the Hopper have a Aerial Antenna hook up yet? | SatelliteGuys.US
ouch1234
88
31
Norman, Ok
I've heard they have some type of USB plug now.. If so. Can you add the OTA channels into the guide like I could with my vip722, and will it show the channels on the joey?
Yes, they have an antenna adapter - I believe it is $30 + shipping from Dish, but can probably be found cheaper elsewhere online (eBay, Dish Depot).
Once you get it you plug it into a USB port and connect your antenna, then scan for channels on the Hopper. Any channels found will show up on the Joey, and you can remove channels you don't want to access. Note that you cannot manually add channels, only ones that are found in the scan.
I've found the Dish OTA Dongle (as they call it) to be an excellent receiver. It's worth the $30. It will lock in on weak stations that neither my Sony or Panasonic TV's will lock in on.
Larry
SF
Hopper S419 Joey S358 Update
External hard drive activation fee?!
