Does the DP34 switch have problems with 129? | SatelliteGuys.US
Try bypassing the switch with a barrel connector to each of the satellite wires. First try 110, then 119, then 129, doing a check switch each time to see if each signal comes in. If each signal comes in yet you do not get a signal through the DP-34 switch then it is time to get it replaced.
A properly functioning DP34 shouldn't have a problem with 129. Try the suggestion above and also make sure that your dish is aligned correctly for that sat.
DP34 cannot band stack (like the DPP33 and DPP44), so ViP dual tuner receivers (222, 612, 622, 722*) must have two lines from the switch to the receiver.
722K users - picture quality compared to 722/622?
61.5 and 148
