Just wondering. 129 signal always steady as a rock, but yesterday afternoon they begin fluctuating all over. One minute a transponder will be 15 db weaker, then 15 minutes later back where it was. Clear skies, new lnbs.
Thanks Star. No problem with branches. I am a long distance from 129 and I guess it is probably some things going on between me and the satellite.They use thrusters to keep them at the correct orbital location or to move it to another location. They could be making changes as well. Also, if you have trees with branches close to in front of the dish in the signal's path and the wind is blowing, that can cause a fluctuation in signal as well.
No drift, new lnbs.There is another possibility. There were some DP lnb's that were out a while back that had manufacturer defects called lnb drift. If you go into your system information screen does it give you some sort of error? What type of dish and receiver do you have? Does the dish have two seperate eyes or are they all built in together?
No drift, new lnbs.
Yeah, we all are, give or take a little bit.I am a long distance from 129...
Limited time offer
