D dzhan SatelliteGuys Family Original poster Jan 10, 2006 41 0 Jan 12, 2006 #1 Hi, Does anybody removed my previous post from this forum? Any reason about that post? Already a lot of reply on that. I still need to look at it through but it seem not there any more.
charper1 Bourbon Tester Supporting Founder May 18, 2004 18,442 6 I'm Nationwide Jan 12, 2006 #2 dzhan said: Does anybody removed my previous post from this forum? Click to expand... Not sure you mean, nor did you say what post you are talking about, but I do see these numerous recent posts by you? You can search all your posts by topic an/or your user name. Some get moved because they are in the wrong area. How to setup a fixed dish and receive IA5 http://www.satelliteguys.us/showthread.php?t=52410 How to tell if the FTA receiver will control dish motor? http://www.satelliteguys.us/showthread.php?t=52377 What is the difference between Universal LNBF and Standard LNBF? http://www.satelliteguys.us/showthread.php?t=52361 techsat Tracker 0.3db LNBF http://www.satelliteguys.us/showthread.php?t=52365 FTA Receiver Recommendation http://www.satelliteguys.us/showthread.php?t=52045 can I access apstar 6 in austin TX? http://www.satelliteguys.us/showthread.php?t=52285 Last edited: Jan 12, 2006
SatinKzo Supporting Founder Supporting Founder May 22, 2004 6,232 83 Louisiana Jan 12, 2006 #3 He lost me after "hi"
Eva Greczkowski The Prize Goddess Staff member HERE TO HELP YOU! Nov 8, 2004 1,432 18 Connecticut Jan 12, 2006 #4 If you click on your user name in your post and then click on find all posts by dzhan. You can then look at all of your previous posts and click on the one you are looking for. Hope that helps!
D dzhan SatelliteGuys Family Original poster Jan 10, 2006 41 0 Jan 12, 2006 #5 Thanks a lot. you guys are really helps.
1 123tim SatelliteGuys Pro Oct 22, 2005 355 0 Pennsylvania Jan 12, 2006 #6 I think that Iceberg merged it here: http://www.satelliteguys.us/showthread.php?t=52377
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,461 15,188 Mankato, MN Jan 13, 2006 #7 I merged two of his topics because they were essentially the same thing. PLease dont start new topics if it is the same thing but worded differently Once you get your setup, keep all the install issues in one topic...it makes it MUCH easier to follow
